Ana içeriğe geç
Asus Q325U Battery Replacement
Neye ihtiyacın var
  1. Asus Q325U Battery Replacement, Back Panel: adım 1, 3 resimden 1. Asus Q325U Battery Replacement, Back Panel: adım 1, 3 resimden 2. Asus Q325U Battery Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the ten 5mm screws using a T5 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Q325U Battery Replacement: adım 2, 3 resimden 1. Asus Q325U Battery Replacement: adım 2, 3 resimden 2. Asus Q325U Battery Replacement: adım 2, 3 resimden 3.
    • Lift the back panel upward using the suction tool.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Q325U Battery Replacement, Battery: adım 3, 2 resimden 1. Asus Q325U Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Q325U Battery Replacement: adım 4, 2 resimden 1. Asus Q325U Battery Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Q325U Battery Replacement: adım 5, 2 resimden 1. Asus Q325U Battery Replacement: adım 5, 2 resimden 2.
    • Lift the battery out from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Flo Costa
235 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G1, White Winter 2019 Cal Poly, Team S19-G1, White Winter 2019 üyesi
CPSU-WHITE-W19S19G1
3 Üyeler
6 adet Kılavuz yazıldı
7Kılavuz Yorumları
Hello,
Can you point me to a place to purchase a replacement battery? Thanks,
Dan Goldman, daniel.goldman@physics.gatech.edu
Dan Goldman - Yanıt Paylaş
Would recommend the screw size be ad to the guide please.
John Walshaw - Yanıt Paylaş
Like Dan, I need to get a replacement battery. Any idea where it can be purchased (safely)?
Thanks :D
Michelle N - Yanıt Paylaş
not able to get beyond step 4. Any ideas how to open the small screws. I tried PH#000, and many others, but no luck
Steve Kumar - Yanıt Paylaş
the battery shown here is not the same for the Q325U, different battery connectors.
Joshua Delgado - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 38
Her zaman: 5,489
