Ana içeriğe geç
Asus Q325U Keyboard Replacement
Neye ihtiyacın var
    1. Asus Q325U Keyboard Replacement, Back Panel: adım 1, 3 resimden 1. Asus Q325U Keyboard Replacement, Back Panel: adım 1, 3 resimden 2. Asus Q325U Keyboard Replacement, Back Panel: adım 1, 3 resimden 3.
      • Remove the ten 5mm screws using a T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q325U Keyboard Replacement: adım 2, 3 resimden 1. Asus Q325U Keyboard Replacement: adım 2, 3 resimden 2. Asus Q325U Keyboard Replacement: adım 2, 3 resimden 3.
      • Lift the back panel upward using the suction tool.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q325U Keyboard Replacement, SSD: adım 3, 2 resimden 1. Asus Q325U Keyboard Replacement, SSD: adım 3, 2 resimden 2.
      • Remove one 2mm screw on top of the SSD using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q325U Keyboard Replacement: adım 4, 2 resimden 1. Asus Q325U Keyboard Replacement: adım 4, 2 resimden 2.
      • Carefully slide and lift the SSD to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q325U Keyboard Replacement, Battery: adım 5, 2 resimden 1. Asus Q325U Keyboard Replacement, Battery: adım 5, 2 resimden 2.
      • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q325U Keyboard Replacement: adım 6, 2 resimden 1. Asus Q325U Keyboard Replacement: adım 6, 2 resimden 2.
      • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q325U Keyboard Replacement: adım 7, 2 resimden 1. Asus Q325U Keyboard Replacement: adım 7, 2 resimden 2.
      • Lift the battery out from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q325U Keyboard Replacement, Copper Plate: adım 8, 2 resimden 1. Asus Q325U Keyboard Replacement, Copper Plate: adım 8, 2 resimden 2.
      • Remove the six 3mm screws using a Phillips #00.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q325U Keyboard Replacement: adım 9, 2 resimden 1. Asus Q325U Keyboard Replacement: adım 9, 2 resimden 2.
      • Use the plastic opening tool to lift up the edge. Pull upward on the edge.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q325U Keyboard Replacement: adım 10, 2 resimden 1. Asus Q325U Keyboard Replacement: adım 10, 2 resimden 2.
      • On the other side of the plate, remove the tape.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q325U Keyboard Replacement, CPU Fan: adım 11, 2 resimden 1. Asus Q325U Keyboard Replacement, CPU Fan: adım 11, 2 resimden 2.
      • Remove the three 3.7 mm screws using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q325U Keyboard Replacement: adım 12, 1 resimden 1.
      • Detach the black wire and plug shown using a tweezer.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q325U Keyboard Replacement: adım 13, 1 resimden 1.
      • Grab CPU fan by its edge and gently pull upwards to remove.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q325U Keyboard Replacement, Motherboard: adım 14, 2 resimden 1. Asus Q325U Keyboard Replacement, Motherboard: adım 14, 2 resimden 2.
      Bu adımda kullanılan alet:
      Halberd Spudger
      $2.99
      • Remove the first connection wire by pulling the small back loop with the Halberd Spudger.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q325U Keyboard Replacement: adım 15, 3 resimden 1. Asus Q325U Keyboard Replacement: adım 15, 3 resimden 2. Asus Q325U Keyboard Replacement: adım 15, 3 resimden 3.
      • Lift the small black tab of the orange connector with your fingers or a plastic opening tool.
      • Remove the orange connector by pulling with tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q325U Keyboard Replacement: adım 16, 3 resimden 1. Asus Q325U Keyboard Replacement: adım 16, 3 resimden 2. Asus Q325U Keyboard Replacement: adım 16, 3 resimden 3.
      • Lift the small black tab on the white plastic piece of the touch pad connector with a spudger.
      • Remove the touch pad connector by pulling with tweezers.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Q325U Keyboard Replacement: adım 17, 3 resimden 1. Asus Q325U Keyboard Replacement: adım 17, 3 resimden 2. Asus Q325U Keyboard Replacement: adım 17, 3 resimden 3.
      • Lift the black tab on the long white plastic piece of the thick blue band.
      • Remove the thick blue band by pulling.
      FixBot'a Sor
      Yorum Ekle
    5. Asus Q325U Keyboard Replacement: adım 18, 3 resimden 1. Asus Q325U Keyboard Replacement: adım 18, 3 resimden 2. Asus Q325U Keyboard Replacement: adım 18, 3 resimden 3.
      • Remove the two Phillips #000 screws on the metal connector above the thick orange band.
      • Lift up the thick orange band.
      FixBot'a Sor
      Yorum Ekle
    6. Asus Q325U Keyboard Replacement: adım 19, 3 resimden 1. Asus Q325U Keyboard Replacement: adım 19, 3 resimden 2. Asus Q325U Keyboard Replacement: adım 19, 3 resimden 3.
      • Gently lift up the two smallest connectors using your fingers or a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    7. Asus Q325U Keyboard Replacement: adım 20, 2 resimden 1. Asus Q325U Keyboard Replacement: adım 20, 2 resimden 2.
      • Lift up the black hinge of the connector using a plastic opening tool.
      • Remove the connector using a tweezer.
      FixBot'a Sor
      Yorum Ekle
    8. Asus Q325U Keyboard Replacement: adım 21, 3 resimden 1. Asus Q325U Keyboard Replacement: adım 21, 3 resimden 2. Asus Q325U Keyboard Replacement: adım 21, 3 resimden 3.
      • Pull up the tap of the biggest connector using your fingers.
      • Lift the gold hinge using a plastic opening tool.
      • Lift the connector up with your fingers to remove.
      FixBot'a Sor
      Yorum Ekle
    9. Asus Q325U Keyboard Replacement: adım 22, 2 resimden 1. Asus Q325U Keyboard Replacement: adım 22, 2 resimden 2.
      • Remove the four 4.8 mm screws using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    10. Asus Q325U Keyboard Replacement: adım 23, 2 resimden 1. Asus Q325U Keyboard Replacement: adım 23, 2 resimden 2.
      • Slightly open up the laptop. This will lift up the hinge at the corner and free the motherboard.
      FixBot'a Sor
      Yorum Ekle
    11. Asus Q325U Keyboard Replacement: adım 24, 2 resimden 1. Asus Q325U Keyboard Replacement: adım 24, 2 resimden 2.
      • Pull the motherboard away from the corner to remove.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q325U Keyboard Replacement, Keyboard: adım 25, 3 resimden 1. Asus Q325U Keyboard Replacement, Keyboard: adım 25, 3 resimden 2. Asus Q325U Keyboard Replacement, Keyboard: adım 25, 3 resimden 3.
      • Remove the three 4 mm screws using a Phillips #00 screwdriver.
      • Remove the four 4.8 mm screws using a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q325U Keyboard Replacement: adım 26, 1 resimden 1.
      • Slide out the blue chip board connected to the long orange piece by gently grabbing the tab and lifting.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q325U Keyboard Replacement: adım 27, 1 resimden 1.
      • Release the single MB wire by removing the black piece of tape.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Q325U Keyboard Replacement: adım 28, 1 resimden 1.
      • Untape the blue striped strip by pulling upwards and laying it flat.
      FixBot'a Sor
      Yorum Ekle
    5. Asus Q325U Keyboard Replacement: adım 29, 3 resimden 1. Asus Q325U Keyboard Replacement: adım 29, 3 resimden 2. Asus Q325U Keyboard Replacement: adım 29, 3 resimden 3.
      • Starting at the upper left corner, remove the black adhesive from the keyboard.
      FixBot'a Sor
      Yorum Ekle
    6. Asus Q325U Keyboard Replacement: adım 30, 2 resimden 1. Asus Q325U Keyboard Replacement: adım 30, 2 resimden 2.
      • Remove eighty 1 mm screws located on the keyboard frame using a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    7. Asus Q325U Keyboard Replacement: adım 31, 1 resimden 1.
      • Grab the edge of the keyboard and lift upwards to remove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Matthew Slawson
271 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G1, White Winter 2019 Cal Poly, Team S19-G1, White Winter 2019 üyesi
CPSU-WHITE-W19S19G1
3 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,016
