Giriş
This guide will demonstrate how to remove the keyboard in your Asus Q325U.
Neye ihtiyacın var
Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
Remove the first connection wire by pulling the small back loop with the Halberd Spudger.
Remove the three 4 mm screws using a Phillips #00 screwdriver.
Remove the four 4.8 mm screws using a Phillips #000 screwdriver.
Neredeyse bitti!
Sonuç
