Ana içeriğe geç
Asus Q500A Battery Replacement
  1. Asus Q500A Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip device onto backside.
  2. Asus Q500A Battery Replacement: adım 2, 1 resimden 1.
    • Locate the two sliding locks.
    • Slide the sliding lock 1 to the right to unlock it .
    • There should be a red marker to indicate that it is unlocked. This lock will stay unlocked until slid back into the locked position.
  3. Asus Q500A Battery Replacement: adım 3, 1 resimden 1.
    • Slide the sliding lock 2 to the left to unlock it.
    • There will not be any indicator that it is unlocked. This lock will relock if you do not continue to push it to the left.
  4. Asus Q500A Battery Replacement: adım 4, 1 resimden 1.
    • While the first and second lock are unlocked, slide the battery out to remove it.
    • When reinserting the replacement battery, make sure to slide sliding lock 1 back into the locked position. Otherwise the battery may come loose.
Sonuç
cameron
319 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-5, Eyestone Spring 2017 USF Tampa, Team 12-5, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 499
