Ana içeriğe geç
Asus Q500A Hard Drive Replacement
Neye ihtiyacın var
  1. Asus Q500A Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Flip device onto backside
  2. Asus Q500A Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use a J0 screwdriver bit to remove both screws on the back-plate, found at the bottom of device.
    • Remove back-plate.
    • Note: Use prying tool if your having issues lifting back-plate.
  3. Asus Q500A Hard Drive Replacement: adım 3, 2 resimden 1. Asus Q500A Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove 4 screws from the metal hard-drive case. There will be one in each corner.
    • Remove the hard-drive case from the device.
  4. Asus Q500A Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the hard-drive. It will be connected to the integrated sata-port in the device.
    • Place hard-drive into slot and connect to the integrated sata port.
    • Place hard drive case back on top of the new hard-drive.
    • Screw in the four screws on the hard-drive case.
  5. Asus Q500A Hard Drive Replacement: adım 6, 1 resimden 1.
    • Place back-plate back on device.
    • Screw in the 2 screws on the back of the plate.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
cameron
319 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-5, Eyestone Spring 2017 USF Tampa, Team 12-5, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 966
