Ana içeriğe geç
Asus Q500A RAM Replacement
Neye ihtiyacın var
  1. Asus Q500A RAM Replacement, RAM: adım 1, 2 resimden 1. Asus Q500A RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Flip device upside-down.
    • Remove back-plate by unscrewing the two screws on either side of the back-plate.
    • Remove the plastic cover.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Q500A RAM Replacement: adım 2, 1 resimden 1.
    • Depending on the model of the device, there will either be one or two sticks of ram.
    • There are two metal brackets holding each ram stick in.
    • To unlock the RAM, you'll need to remove the metal brackets. To do this, carefully push out the brackets.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Q500A RAM Replacement: adım 3, 2 resimden 1. Asus Q500A RAM Replacement: adım 3, 2 resimden 2.
    • Now simply remove the ram by pulling it out using a set of pliers to be safe and careful not to damage the ram.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Q500A RAM Replacement: adım 4, 1 resimden 1.
    • To insert the ram line up the ram stick and the slot.
    • Next you will have to push the ram down until it snaps into place.
    • Be careful not to do this too hard, as it can break the ram.
    • Make sure the ram is secure in its slot before moving on to the next piece of ram or replacing the back-plate.
    FixBot'a Sor
    Yorum Ekle
Sonuç
cameron
319 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-5, Eyestone Spring 2017 USF Tampa, Team 12-5, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 1,084
