Ana içeriğe geç
Asus Q501LA-BBI6T03 Back Panel Replacement
Neye ihtiyacın var
  1. Asus Q501LA-BBI6T03 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Back Panel Replacement: adım 2, 1 resimden 1.
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Back Panel Replacement: adım 3, 2 resimden 1. Asus Q501LA-BBI6T03 Back Panel Replacement: adım 3, 2 resimden 2.
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tanner
276 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-1, Banghart Winter 2017 Cal Poly, Team 8-1, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G1
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
I got one of these model, how much RAM is the maximum amount supported?
Cesar Aguilar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 611
