Ana içeriğe geç
Asus Q501LA-BBI6T03 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus Q501LA-BBI6T03 Hard Drive Replacement, Back Panel: adım 1, 1 resimden 1.
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Hard Drive Replacement: adım 3, 2 resimden 1. Asus Q501LA-BBI6T03 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Remove the four 3mm Phillips #0 screws shown.
  5. Asus Q501LA-BBI6T03 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Take hard drive out of the port by sliding the component to the left.
    • There is only one way it comes out of the connector. If it seems too hard to push out you are probably going the wrong way.
  6. Asus Q501LA-BBI6T03 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Once the hard drive has been removed from the connector, use your thumb to get under and lift the hard drive out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Aodhan Arias
288 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-1, Banghart Winter 2017 Cal Poly, Team 8-1, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 2,658
