Giriş
If your laptop is running hot, you may decide to either replace or clean out your fan unit, and replace the thermal compound with better quality.
Neye ihtiyacın var
Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
Remove the seven 4mm Phillips #0 screws holding the heat sink/fan assembly onto the motherboard.
Bir başkası bu kılavuzu tamamladı.
