Ana içeriğe geç
Asus Q502LA-BSI5T14 Fan Replacement
Neye ihtiyacın var
  1. Asus Q502LA-BSI5T14 Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Make sure your device is powered off before you begin.
    • Flip the laptop over and remove the ten 11 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Fan Replacement: adım 2, 1 resimden 1.
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Fan Replacement: adım 3, 1 resimden 1.
    • Remove the eight 5 mm Phillips #1 screws securing the fan and copper piece to the motherboard.
    • Remove the wires by gently pulling them out.
  4. Asus Q502LA-BSI5T14 Fan Replacement: adım 4, 1 resimden 1.
    • Gently lift the fan up and away from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mary Kounelas
715 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G1, Eyestone Fall 2017 USF Tampa, Team S4-G1, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 392
