Ana içeriğe geç
Asus Q502LA-BSI5T14 RAM Replacement
Neye ihtiyacın var
  1. Asus Q502LA-BSI5T14 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Ensure your device is powered off before starting
    • Flip the laptop so the back panel is facing up.
    • Remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 RAM Replacement: adım 2, 1 resimden 1.
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 RAM Replacement: adım 3, 3 resimden 1. Asus Q502LA-BSI5T14 RAM Replacement: adım 3, 3 resimden 2. Asus Q502LA-BSI5T14 RAM Replacement: adım 3, 3 resimden 3.
    • The RAM is the rectangular plate in the center.
    • Use a spudger to press the clips securing the RAM outward. The RAM will pop up enabling you to lift it out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mary Kounelas
715 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G1, Eyestone Fall 2017 USF Tampa, Team S4-G1, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 548
