Ana içeriğe geç
Asus Q503UA Battery Replacement
Neye ihtiyacın var
  1. Asus Q503UA Battery Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA Battery Replacement: adım 2, 2 resimden 1. Asus Q503UA Battery Replacement: adım 2, 2 resimden 2.
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA Battery Replacement: adım 3, 3 resimden 1. Asus Q503UA Battery Replacement: adım 3, 3 resimden 2. Asus Q503UA Battery Replacement: adım 3, 3 resimden 3.
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
Sonuç
To reinstall the back cover, follow these instructions in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
Gilberto Coronado
145 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team S1-G4, Saknee Fall 2019 Gateway, Team S1-G4, Saknee Fall 2019 üyesi
GCC-SAKNEE-F19S1G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 494
