Ana içeriğe geç
Asus Q504UA-BHI5T13 Back Panel Replacement
Neye ihtiyacın var
  1. Asus Q504UA-BHI5T13 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Back Panel Replacement: adım 2, 1 resimden 1.
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Back Panel Replacement: adım 3, 1 resimden 1.
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Back Panel Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Back Panel Replacement: adım 5, 1 resimden 1.
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Johnathan Teav
456 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G4, Thompson Fall 2017 USF Tampa, Team S10-G4, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 972
