Giriş
Speakers would need to be removed if the user wanted to upgrade their current speakers or if the current speakers are not functioning properly. Before thinking about removing the speakers, check the settings to make sure the volume is on as the volume may have been too low.
The battery must be removed prior to the speakers. When removing the speakers, handle them as well as the wire stringing them together with care.
Neye ihtiyacın var
Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
We will start with the left speaker. The left speaker is the one with the letter “L” on it. Use the Phillips #0 screwdriver to remove the two 4mm screws around the left speaker.
This is the screw that is shared with the battery. This screw will be removed once the battery is removed.
