Ana içeriğe geç
Asus Q505UA-BI5T7 Back Cover Replacement
Neye ihtiyacın var
  1. Asus Q505UA-BI5T7 Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Asus Q505UA-BI5T7 Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip the device over so that the back cover is facing you.
    • Ensure that the device is turned off.
    • Remove the two 10 mm Philips #1 screws from the top two corners of the back cover of the laptop.
    • Remove the remaining eight 8 mm Philips #1 screws remaining in the back cover of the laptop.
  2. Asus Q505UA-BI5T7 Back Cover Replacement: adım 2, 3 resimden 1. Asus Q505UA-BI5T7 Back Cover Replacement: adım 2, 3 resimden 2. Asus Q505UA-BI5T7 Back Cover Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to gently pry the back cover of the laptop up. Slide the tool slowly along the edges of the back cover to pop it out of the clips holding the cover in place.
  3. Asus Q505UA-BI5T7 Back Cover Replacement: adım 3, 1 resimden 1.
    • Gently remove the cover and lift it off of the back of the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 782
