Ana içeriğe geç
Asus Q524U Battery Replacement
Neye ihtiyacın var
  1. Asus Q524U Battery Replacement, Back Panel: adım 1, 2 resimden 1. Asus Q524U Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove ten 3 mm screws using a Phillips #0 screwdriver.
  2. Asus Q524U Battery Replacement: adım 2, 1 resimden 1.
    • Lift up the back panel and set it to the side.
  3. Asus Q524U Battery Replacement, Battery: adım 3, 2 resimden 1. Asus Q524U Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Using your fingers, grip onto both sides of the wire harness and push it upwards.
  4. Asus Q524U Battery Replacement: adım 4, 2 resimden 1. Asus Q524U Battery Replacement: adım 4, 2 resimden 2.
    • Remove the five 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
  5. Asus Q524U Battery Replacement: adım 5, 3 resimden 1. Asus Q524U Battery Replacement: adım 5, 3 resimden 2. Asus Q524U Battery Replacement: adım 5, 3 resimden 3.
    • Tilt the small black tab up which will allow the blue tape to be slid out.
  6. Asus Q524U Battery Replacement: adım 6, 1 resimden 1.
    • Simply lift the battery up and out of its holding area.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 296
