Neye ihtiyacın var
Using your fingers, grip onto both sides of the wire harness and push it upwards.
Remove the four 3 mm screws holding the fan in place using a Phillips #0 screwdriver.
Remove the seven screws attached to the motherboard using a Phillips #0 screwdriver.
Remove the five screws from the daughterboard using a Phillips #0 screwdriver.
Neredeyse bitti!
Sonuç
