Ana içeriğe geç
Asus Q524U Fan Assembly Replacement
Neye ihtiyacın var
  1. Asus Q524U Fan Assembly Replacement, Back Panel: adım 1, 2 resimden 1. Asus Q524U Fan Assembly Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove ten 3 mm screws using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Q524U Fan Assembly Replacement: adım 2, 1 resimden 1.
    • Lift up the back panel and set it to the side.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Q524U Fan Assembly Replacement, Battery: adım 3, 2 resimden 1. Asus Q524U Fan Assembly Replacement, Battery: adım 3, 2 resimden 2.
    • Using your fingers, grip onto both sides of the wire harness and push it upwards.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Q524U Fan Assembly Replacement: adım 4, 2 resimden 1. Asus Q524U Fan Assembly Replacement: adım 4, 2 resimden 2.
    • Remove the five 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Q524U Fan Assembly Replacement: adım 5, 3 resimden 1. Asus Q524U Fan Assembly Replacement: adım 5, 3 resimden 2. Asus Q524U Fan Assembly Replacement: adım 5, 3 resimden 3.
    • Tilt the small black tab up which will allow the blue tape to be slid out.
    FixBot'a Sor
    Yorum Ekle
  6. Asus Q524U Fan Assembly Replacement: adım 6, 1 resimden 1.
    • Simply lift the battery up and out of its holding area.
    FixBot'a Sor
    Yorum Ekle
  7. Asus Q524U Fan Assembly Replacement, Fan Assembly: adım 7, 1 resimden 1.
    • Remove the four 3 mm screws holding the fan in place using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Asus Q524U Fan Assembly Replacement: adım 8, 2 resimden 1. Asus Q524U Fan Assembly Replacement: adım 8, 2 resimden 2.
    • Remove five 3 mm screws holding the heat sink in place using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Asus Q524U Fan Assembly Replacement: adım 9, 3 resimden 1. Asus Q524U Fan Assembly Replacement: adım 9, 3 resimden 2. Asus Q524U Fan Assembly Replacement: adım 9, 3 resimden 3.
    • Pull up fan connector tab by using the plastic handle.
    FixBot'a Sor
    Yorum Ekle
  10. Asus Q524U Fan Assembly Replacement: adım 10, 2 resimden 1. Asus Q524U Fan Assembly Replacement: adım 10, 2 resimden 2.
    • Unwind the cable wrapped around the fan casing.
    FixBot'a Sor
    Yorum Ekle
  11. Asus Q524U Fan Assembly Replacement: adım 11, 1 resimden 1.
    • Disconnect the small cable from the fan.
    FixBot'a Sor
    Yorum Ekle
  12. Asus Q524U Fan Assembly Replacement: adım 12, 1 resimden 1.
    • After all screws and cables are unsecured, lift the fan assembly out of the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 386
