Ana içeriğe geç
Asus Q525U Back Cover Replacement
Neye ihtiyacın var
  1. Asus Q525U Back Cover Replacement, Back Cover: adım 1, 3 resimden 1. Asus Q525U Back Cover Replacement, Back Cover: adım 1, 3 resimden 2. Asus Q525U Back Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Q525U Back Cover Replacement: adım 2, 3 resimden 1. Asus Q525U Back Cover Replacement: adım 2, 3 resimden 2. Asus Q525U Back Cover Replacement: adım 2, 3 resimden 3.
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Q525U Back Cover Replacement: adım 3, 3 resimden 1. Asus Q525U Back Cover Replacement: adım 3, 3 resimden 2. Asus Q525U Back Cover Replacement: adım 3, 3 resimden 3.
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stewart Crandall
613 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-5, Hunter Spring 2022 Clemson, Team 2-5, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G5
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 1,152
