Ana içeriğe geç
Asus Q525U CPU Fan Replacement
Neye ihtiyacın var
  1. Asus Q525U CPU Fan Replacement, Back Cover: adım 1, 3 resimden 1. Asus Q525U CPU Fan Replacement, Back Cover: adım 1, 3 resimden 2. Asus Q525U CPU Fan Replacement, Back Cover: adım 1, 3 resimden 3.
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Q525U CPU Fan Replacement: adım 2, 3 resimden 1. Asus Q525U CPU Fan Replacement: adım 2, 3 resimden 2. Asus Q525U CPU Fan Replacement: adım 2, 3 resimden 3.
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Q525U CPU Fan Replacement: adım 3, 3 resimden 1. Asus Q525U CPU Fan Replacement: adım 3, 3 resimden 2. Asus Q525U CPU Fan Replacement: adım 3, 3 resimden 3.
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Q525U CPU Fan Replacement, Battery: adım 4, 3 resimden 1. Asus Q525U CPU Fan Replacement, Battery: adım 4, 3 resimden 2. Asus Q525U CPU Fan Replacement, Battery: adım 4, 3 resimden 3.
    • The battery of the device is outlined in red.
    • Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Q525U CPU Fan Replacement: adım 5, 2 resimden 1. Asus Q525U CPU Fan Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    • Using the Halberd spudger, carefully lift the battery connector up to disconnect it from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Asus Q525U CPU Fan Replacement: adım 6, 1 resimden 1.
    • Lift the battery out of the frame to remove.
    FixBot'a Sor
    Yorum Ekle
  7. Asus Q525U CPU Fan Replacement, CPU Fan: adım 7, 1 resimden 1.
    • The CPU fan of this device is outlined in purple.
    FixBot'a Sor
    Yorum Ekle
  8. Asus Q525U CPU Fan Replacement: adım 8, 3 resimden 1. Asus Q525U CPU Fan Replacement: adım 8, 3 resimden 2. Asus Q525U CPU Fan Replacement: adım 8, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove five screws from the fan and heatsink.
    • Remove one 3 mm Phillips #1 screw on the side of the CPU fan.
    • Remove four 2 mm Phillips #1 screws from the heatsink.
    FixBot'a Sor
    Yorum Ekle
  9. Asus Q525U CPU Fan Replacement: adım 9, 2 resimden 1. Asus Q525U CPU Fan Replacement: adım 9, 2 resimden 2.
    Halberd Spudger
    $2.99
    • Use the Halberd spudger to carefully disconnect the bundled slide connector that connects the CPU fan to the motherboard.
    • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    FixBot'a Sor
    Yorum Ekle
  10. Asus Q525U CPU Fan Replacement: adım 10, 3 resimden 1. Asus Q525U CPU Fan Replacement: adım 10, 3 resimden 2. Asus Q525U CPU Fan Replacement: adım 10, 3 resimden 3.
    • Carefully remove the thicker black cord from the cord clips surrounding the fan.
    • Remove the fan from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Stewart Crandall
613 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-5, Hunter Spring 2022 Clemson, Team 2-5, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G5
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 829
