Ana içeriğe geç
Asus Q525U Hard Drive Replacement
Neye ihtiyacın var
  1. Asus Q525U Hard Drive Replacement, Back Cover: adım 1, 3 resimden 1. Asus Q525U Hard Drive Replacement, Back Cover: adım 1, 3 resimden 2. Asus Q525U Hard Drive Replacement, Back Cover: adım 1, 3 resimden 3.
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Q525U Hard Drive Replacement: adım 2, 3 resimden 1. Asus Q525U Hard Drive Replacement: adım 2, 3 resimden 2. Asus Q525U Hard Drive Replacement: adım 2, 3 resimden 3.
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Q525U Hard Drive Replacement: adım 3, 3 resimden 1. Asus Q525U Hard Drive Replacement: adım 3, 3 resimden 2. Asus Q525U Hard Drive Replacement: adım 3, 3 resimden 3.
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Q525U Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • The hard drive is located to the left of the battery and below the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Q525U Hard Drive Replacement: adım 5, 2 resimden 1. Asus Q525U Hard Drive Replacement: adım 5, 2 resimden 2.
    • Remove the two 4 mm Phillips #1 screws which are holding the hard drive cover in place.
    FixBot'a Sor
    Yorum Ekle
  6. Asus Q525U Hard Drive Replacement: adım 6, 2 resimden 1. Asus Q525U Hard Drive Replacement: adım 6, 2 resimden 2.
    • The hard drive cover is now easily accessible.
    • Lift the cover off, exposing the hard drive underneath [this laptop is missing its hard drive].
    • If replacing the hard drive, lift it up on the right side slightly and pull it from the connecter on the left.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Stewart Crandall
613 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-5, Hunter Spring 2022 Clemson, Team 2-5, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G5
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 3,745
