Ana içeriğe geç
Asus Q525U RAM Replacement
Neye ihtiyacın var
    1. Asus Q525U RAM Replacement, Back Cover: adım 1, 3 resimden 1. Asus Q525U RAM Replacement, Back Cover: adım 1, 3 resimden 2. Asus Q525U RAM Replacement, Back Cover: adım 1, 3 resimden 3.
      • Begin by powering off the device and flipping the device over.
      • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
      • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q525U RAM Replacement: adım 2, 3 resimden 1. Asus Q525U RAM Replacement: adım 2, 3 resimden 2. Asus Q525U RAM Replacement: adım 2, 3 resimden 3.
      • Use an opening pick to separate the back cover from the device.
      • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q525U RAM Replacement: adım 3, 3 resimden 1. Asus Q525U RAM Replacement: adım 3, 3 resimden 2. Asus Q525U RAM Replacement: adım 3, 3 resimden 3.
      • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
      • The back cover should be easily removable, allowing full access to all of the internal components.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q525U RAM Replacement, RAM: adım 4, 1 resimden 1.
      • Position the flat end of the Spudger under one of the corners on the RAM cover and pry it up slightly.
      • Move the spudger around the periphery of the cover to lift the cover up.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q525U RAM Replacement: adım 5, 1 resimden 1.
      • Lift the RAM cover off.
      • The RAM should now be fully exposed.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q525U RAM Replacement: adım 6, 3 resimden 1. Asus Q525U RAM Replacement: adım 6, 3 resimden 2. Asus Q525U RAM Replacement: adım 6, 3 resimden 3.
      • Using a spudger or your fingers, gently pull the metal brackets away from the RAM.
      • After pulling both brackets away from the component, the RAM should release at an upward angle (allowing for removal and replacement).
      FixBot'a Sor
      Yorum Ekle
    4. Asus Q525U RAM Replacement: adım 7, 1 resimden 1.
      • Slide the RAM stick out of the socket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stewart Crandall
634 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-5, Hunter Spring 2022 Clemson, Team 2-5, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G5
4 Üyeler
38 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 1,607
