Ana içeriğe geç
Asus Q525U Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Asus Q525U Wi-Fi Card Replacement, Back Cover: adım 1, 3 resimden 1. Asus Q525U Wi-Fi Card Replacement, Back Cover: adım 1, 3 resimden 2. Asus Q525U Wi-Fi Card Replacement, Back Cover: adım 1, 3 resimden 3.
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
  2. Asus Q525U Wi-Fi Card Replacement: adım 2, 3 resimden 1. Asus Q525U Wi-Fi Card Replacement: adım 2, 3 resimden 2. Asus Q525U Wi-Fi Card Replacement: adım 2, 3 resimden 3.
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
  3. Asus Q525U Wi-Fi Card Replacement: adım 3, 3 resimden 1. Asus Q525U Wi-Fi Card Replacement: adım 3, 3 resimden 2. Asus Q525U Wi-Fi Card Replacement: adım 3, 3 resimden 3.
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
  4. Asus Q525U Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 2 resimden 1. Asus Q525U Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 2 resimden 2.
    • The Wi-Fi card is located above the CMOS coin cell battery and below one of the hinges.
    • Using a Phillips #1 screwdriver, remove one 2 mm screw, that holds the card in place.
  5. Asus Q525U Wi-Fi Card Replacement: adım 5, 1 resimden 1.
    • Use a pair of pointed tweezers to disconnect the small black and white coaxial connectors from the Wi-Fi card.
  6. Asus Q525U Wi-Fi Card Replacement: adım 6, 2 resimden 1. Asus Q525U Wi-Fi Card Replacement: adım 6, 2 resimden 2.
    • Use the pointed tweezers to pull the network card out and away from the socket.
Sonuç
Stewart Crandall
550 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-5, Hunter Spring 2022 Clemson, Team 2-5, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G5
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 192
