Ana içeriğe geç
Asus Q534U CPU Fan/Heat Sink Replacement
Neye ihtiyacın var
  1. Asus Q534U CPU Fan/Heat Sink Replacement, Back Case Removal: adım 1, 1 resimden 1.
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U CPU Fan/Heat Sink Replacement: adım 2, 2 resimden 1. Asus Q534U CPU Fan/Heat Sink Replacement: adım 2, 2 resimden 2.
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U CPU Fan/Heat Sink Replacement: adım 3, 2 resimden 1. Asus Q534U CPU Fan/Heat Sink Replacement: adım 3, 2 resimden 2.
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U CPU Fan/Heat Sink Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: adım 5, 2 resimden 1. Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: adım 5, 2 resimden 2.
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  6. Asus Q534U CPU Fan/Heat Sink Replacement: adım 6, 2 resimden 1. Asus Q534U CPU Fan/Heat Sink Replacement: adım 6, 2 resimden 2.
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
mmedina
749 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 UMass Dartmouth, Team S66-G6, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S66G6
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Is it possible to replace the fan only without removing the full heatsink or is it fused together as one unit?
Bork Bois - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 32
Her zaman: 2,898
