Ana içeriğe geç
Asus Q534U Motherboard Replacement
Neye ihtiyacın var
    1. Asus Q534U Motherboard Replacement, Back Case: adım 1, 3 resimden 1. Asus Q534U Motherboard Replacement, Back Case: adım 1, 3 resimden 2. Asus Q534U Motherboard Replacement, Back Case: adım 1, 3 resimden 3.
      • Remove ten screws with the T5 driver.
      • Use the opening tool to carefully pry off the back case.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: adım 2, 2 resimden 1. Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: adım 2, 2 resimden 2.
      • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q534U Motherboard Replacement: adım 3, 2 resimden 1. Asus Q534U Motherboard Replacement: adım 3, 2 resimden 2.
      • Move the black cable located around the CPU fan out of the holder.
      • Remove the following 9 screws:
      • Three Phillips screws
      • Six Phillips screws
      • Make sure not to mix up both types of screws.
      • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
      • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q534U Motherboard Replacement, Hard Drive: adım 4, 2 resimden 1. Asus Q534U Motherboard Replacement, Hard Drive: adım 4, 2 resimden 2.
      • Remove four screws with the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q534U Motherboard Replacement: adım 5, 2 resimden 1. Asus Q534U Motherboard Replacement: adım 5, 2 resimden 2.
      • Gently lift the hard disk out using the black tab.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q534U Motherboard Replacement: adım 6, 1 resimden 1.
      • Using a Phillips #00 screwdriver remove the four screws of the metal casing
      • Remove the hard disk from the metal casing
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q534U Motherboard Replacement, Motherboard: adım 7, 3 resimden 1. Asus Q534U Motherboard Replacement, Motherboard: adım 7, 3 resimden 2. Asus Q534U Motherboard Replacement, Motherboard: adım 7, 3 resimden 3.
      • Disconnect the four marked cables connectors at the sockets.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q534U Motherboard Replacement: adım 8, 3 resimden 1. Asus Q534U Motherboard Replacement: adım 8, 3 resimden 2. Asus Q534U Motherboard Replacement: adım 8, 3 resimden 3.
      • Lift the connecting ports up prior to removing the connectors.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q534U Motherboard Replacement: adım 9, 3 resimden 1. Asus Q534U Motherboard Replacement: adım 9, 3 resimden 2. Asus Q534U Motherboard Replacement: adım 9, 3 resimden 3.
      • Remove the screws holding the hinges down on both sides of the device.
      • A pry tool might be needed to lift the hinge.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Q534U Motherboard Replacement: adım 10, 1 resimden 1.
      • Remove nine, 3.2 mm screws to fully release motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jacob Pauker
238 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G9, Hovde Fall 2019 IUPUI, Team S1-G9, Hovde Fall 2019 üyesi
IUPUI-HOVDE-F19S1G9
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 58
Her zaman: 2,724
