Ana içeriğe geç
Asus Q534U Motherboard Replacement
Neye ihtiyacın var
  1. Asus Q534U Motherboard Replacement, Back Case: adım 1, 3 resimden 1. Asus Q534U Motherboard Replacement, Back Case: adım 1, 3 resimden 2. Asus Q534U Motherboard Replacement, Back Case: adım 1, 3 resimden 3.
    • Remove ten screws with the T5 driver.
    • Use the opening tool to carefully pry off the back case.
  2. Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: adım 2, 2 resimden 1. Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: adım 2, 2 resimden 2.
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  3. Asus Q534U Motherboard Replacement: adım 3, 2 resimden 1. Asus Q534U Motherboard Replacement: adım 3, 2 resimden 2.
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
  4. Asus Q534U Motherboard Replacement, Hard Drive: adım 4, 2 resimden 1. Asus Q534U Motherboard Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Remove four screws with the Phillips #00 screwdriver.
  5. Asus Q534U Motherboard Replacement: adım 5, 2 resimden 1. Asus Q534U Motherboard Replacement: adım 5, 2 resimden 2.
    • Gently lift the hard disk out using the black tab.
  6. Asus Q534U Motherboard Replacement: adım 6, 1 resimden 1.
    • Using a Phillips #00 screwdriver remove the four screws of the metal casing
    • Remove the hard disk from the metal casing
  7. Asus Q534U Motherboard Replacement, Motherboard: adım 7, 3 resimden 1. Asus Q534U Motherboard Replacement, Motherboard: adım 7, 3 resimden 2. Asus Q534U Motherboard Replacement, Motherboard: adım 7, 3 resimden 3.
    • Disconnect the four marked cables connectors at the sockets.
  8. Asus Q534U Motherboard Replacement: adım 8, 3 resimden 1. Asus Q534U Motherboard Replacement: adım 8, 3 resimden 2. Asus Q534U Motherboard Replacement: adım 8, 3 resimden 3.
    • Lift the connecting ports up prior to removing the connectors.
  9. Asus Q534U Motherboard Replacement: adım 9, 3 resimden 1. Asus Q534U Motherboard Replacement: adım 9, 3 resimden 2. Asus Q534U Motherboard Replacement: adım 9, 3 resimden 3.
    • Remove the screws holding the hinges down on both sides of the device.
    • A pry tool might be needed to lift the hinge.
  10. Asus Q534U Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove nine, 3.2 mm screws to fully release motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jacob Pauker
228 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G9, Hovde Fall 2019 IUPUI, Team S1-G9, Hovde Fall 2019 üyesi
IUPUI-HOVDE-F19S1G9
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 1,946
