Ana içeriğe geç
Asus Q534U RAM Replacement
Neye ihtiyacın var
    1. Asus Q534U RAM Replacement, Back Case Removal: adım 1, 1 resimden 1.
      • Make sure the device is turned off and unplugged from the charger.
      • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
      • Pull off the back cover of the laptop.
      • A pry tool may be needed to pull off the back cover.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q534U RAM Replacement: adım 2, 2 resimden 1. Asus Q534U RAM Replacement: adım 2, 2 resimden 2.
      • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q534U RAM Replacement: adım 3, 2 resimden 1. Asus Q534U RAM Replacement: adım 3, 2 resimden 2.
      • Lift up the black tab next to the silver ribbon cable.
      • Pull lightly on the blue tabs until the silver cable is free.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Q534U RAM Replacement: adım 4, 1 resimden 1.
      • Use a Phillips #00 screwdriver to remove the 5 marked screws.
      • Gently remove the battery.
      • Do not bend or puncture the laptop's lithium-polymer pattery.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q534U RAM Replacement, RAM: adım 5, 3 resimden 1. Asus Q534U RAM Replacement, RAM: adım 5, 3 resimden 2. Asus Q534U RAM Replacement, RAM: adım 5, 3 resimden 3.
      • Locate the metal RAM cover
      • Pull the metal tab on the corner of the metal cover to lift the cover from its clips
      • A pry tool may provide a better grip on small tab.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q534U RAM Replacement: adım 6, 3 resimden 1. Asus Q534U RAM Replacement: adım 6, 3 resimden 2. Asus Q534U RAM Replacement: adım 6, 3 resimden 3.
      • While pushing out the metal clips on both sides of the RAM, lift up the RAM to release it
      • Pull the RAM out gently and bring it up from the slot
      • Make sure to pull out first and then pull the RAM up out of place
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Kyle Whalen
181 İtibar
1 Kılavuz yazıldı
4Kılavuz Yorumları
One question: I have this model and have determined that I have a bad stick of RAM. I have removed this stick but still have 8 gigs available. Is there another stick that I m not seeing or is this built in?
Elijah Elliott - Yanıt Paylaş
saame here must be another stick somewhere
SvGGRK - Yanıt Paylaş
There are 4, 2GB chips of ram, hard built into the motherboard. Located right above the SSD m.2 bay, and beside the copper cooling line. This model of Laptop has one RAM bay, I'm not sure how the Built in and Bay RAM work together but for all intents and purposes, just assume you are only using the Bay for RAM. @svggrk @elijahelliott
Nirlicnick - Yanıt Paylaş
This is too old but I hope someone can help me. I open the memory section just to clean all the dust accumulated there. After putting everything back laptop is bricked... Battery led is green. Power led is on but laptop is not booting. Any ideas?
Mario Venegas - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 77
Her zaman: 8,307
