Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If your Asus laptop (Q534U) is having problems connecting to WiFi, then the solution may be as simple as switching out a faulty WiFi card. First, be sure to eliminate all the possible errors with the laptop. Once the problem has been narrowed down to the WiFi card, use this guide to walk you through the steps of changing the WiFi card. This fix should not take more than 20 minutes, and only requires removal of parts.
It does require removing the battery, so use caution as a punctured battery can cause a dangerous fire.
  1. Make sure the device  is turned off and unplugged from  the charger.
    • Make sure the device is turned off and unplugged from the charger.
    • Using a T5 screwdriver, remove all 10 screws located on the underside of the laptop.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Lift up the black tab next to the silver ribbon cable. Pull lightly on the blue tabs until the silver cable is free.
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  3. Using a Phillips #00 screwdriver, remove the 5 marked screws.
    • Using a Phillips #00 screwdriver, remove the 5 marked screws.
  4. Locate the battery connector. Wedge a pry tool under the battery connector.
    • Locate the battery connector.
    • Wedge a pry tool under the battery connector.
    • Gently pull on the connector until it disconnects from the base of the object.
    • Lift the battery out of the computer.
  5. Disconnect the WiFi antenna cables by gently pulling them in an upwards motion.
    • Disconnect the WiFi antenna cables by gently pulling them in an upwards motion.
    • Needle nose pliers can be used as a detaching tool.
  6. Using a Phillips #0 screwdriver, remove the screw holding the WiFi card down.
    • Using a Phillips #0 screwdriver, remove the screw holding the WiFi card down.
    • Pull the WiFi card out of the socket toward the fan housing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eric Okoko
302 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 UMass Dartmouth, Team S66-G6, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S66G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 904
