Ana içeriğe geç
Asus Q550LF-BBI7T07 Disc Drive Replacement
Neye ihtiyacın var
  1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: adım 1, 2 resimden 1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 2, 2 resimden 1. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 2, 2 resimden 2.
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 3, 2 resimden 1. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 4, 2 resimden 1. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 4, 2 resimden 2.
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: adım 5, 2 resimden 1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: adım 5, 2 resimden 2.
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 6, 2 resimden 1. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 6, 2 resimden 2.
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: adım 7, 2 resimden 1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: adım 7, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 8, 1 resimden 1.
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 9, 2 resimden 1. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 9, 2 resimden 2.
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 10, 2 resimden 1. Asus Q550LF-BBI7T07 Disc Drive Replacement: adım 10, 2 resimden 2.
    • Slowly slide out the disc drive, keeping it level, to remove it.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 412
