Giriş
If your disc drive on the laptop does not open or read discs, it may need to be replaced. In this guide, we will show you how to replace the disc drive.
Neye ihtiyacın var
Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
Neredeyse bitti!
Sonuç
