Ana içeriğe geç
Asus Q550LF-BBI7T07 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus Q550LF-BBI7T07 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Asus Q550LF-BBI7T07 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Hard Drive Replacement: adım 2, 2 resimden 1. Asus Q550LF-BBI7T07 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Hard Drive Replacement: adım 3, 2 resimden 1. Asus Q550LF-BBI7T07 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Hard Drive Replacement: adım 4, 2 resimden 1. Asus Q550LF-BBI7T07 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 1. Asus Q550LF-BBI7T07 Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 2.
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Hard Drive Replacement: adım 6, 2 resimden 1. Asus Q550LF-BBI7T07 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 15
Her zaman: 1,589
