Ana içeriğe geç
Asus Q550LF-BBI7T07 Motherboard Replacement
Neye ihtiyacın var
  1. Asus Q550LF-BBI7T07 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 2, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 3, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 4, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 4, 2 resimden 2.
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Motherboard Replacement, Hard Drive: adım 5, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement, Hard Drive: adım 5, 2 resimden 2.
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 6, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 6, 2 resimden 2.
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Motherboard Replacement, Disc Drive: adım 7, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement, Disc Drive: adım 7, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 8, 1 resimden 1.
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 9, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 9, 2 resimden 2.
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 10, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 10, 2 resimden 2.
    • Slowly slide out the disc drive, keeping it level, to remove it.
  11. Asus Q550LF-BBI7T07 Motherboard Replacement, RAM: adım 11, 3 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement, RAM: adım 11, 3 resimden 2. Asus Q550LF-BBI7T07 Motherboard Replacement, RAM: adım 11, 3 resimden 3.
    • Push both metal tabs away from each other on each side of the RAM farthest from battery so that the RAM will pop up.
  12. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 12, 1 resimden 1.
    • Pull out first RAM chip.
  13. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 13, 1 resimden 1.
    • Push both metal tabs away from each other on each side of the RAM closest to the battery so that the second RAM will pop up.
  14. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 14, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 14, 2 resimden 2.
    • Pull out second RAM chip.
  15. Asus Q550LF-BBI7T07 Motherboard Replacement, Motherboard: adım 15, 3 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement, Motherboard: adım 15, 3 resimden 2. Asus Q550LF-BBI7T07 Motherboard Replacement, Motherboard: adım 15, 3 resimden 3.
    • Remove the ten screws surrounding the fan and cooling assembly using a Phillips #0 screwdriver.
    • Remove the two silver 5 mm Phillips head screws that hold the fan in place.
    • Remove the eight black 4 mm Phillips head screws that hold the fan in place.
  16. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 16, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 16, 2 resimden 2.
    • Disconnect the multi-colored cable that attaches the fan to the motherboard.
    • Pick the fan up to remove it from the motherboard.
  17. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 17, 3 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 17, 3 resimden 2. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 17, 3 resimden 3.
    • Use the Phillips #0 Screwdriver to remove the four screws on the edge of the motherboard;
    • Remove the one black 3 mm screw.
    • Remove the three silver 5 mm screws.
  18. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 18, 1 resimden 1.
    • Use the Phillips #0 Screwdriver to remove the remaining four black 7 mm screws on the edge of the motherboard.
  19. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 19, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 19, 2 resimden 2.
    • Disconnect the five cables that are attached to the motherboard by gently pulling them.
    • Disconnect the four remaining cables attached to the motherboard by lifting the tabs and gently pulling them out.
  20. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 20, 2 resimden 1. Asus Q550LF-BBI7T07 Motherboard Replacement: adım 20, 2 resimden 2.
    • Use the metal spudger to pry and lift the silver hinge that is connected to the motherboard to release it.
    • Pull the motherboard out by hand in a counterclockwise motion to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 1,507
