Ana içeriğe geç
Asus Q551L Battery Replacement
Neye ihtiyacın var
  1. Asus Q551L Battery Replacement, Back Panel: adım 1, 2 resimden 1. Asus Q551L Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Q551L Battery Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Q551L Battery Replacement, Battery: adım 3, 2 resimden 1. Asus Q551L Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Unscrew the four screws to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Q551L Battery Replacement: adım 4, 2 resimden 1. Asus Q551L Battery Replacement: adım 4, 2 resimden 2.
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Is there a part to order if the solder gives from the mother board connection peice. My cable came up from the board with connection still attached
wolf brown - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 8,066
