Ana içeriğe geç
Asus Q551L Repair Motherboard Replacement
Neye ihtiyacın var
  1. Asus Q551L Repair Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Asus Q551L Repair Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Motherboard Replacement, Battery: adım 3, 2 resimden 1. Asus Q551L Repair Motherboard Replacement, Battery: adım 3, 2 resimden 2.
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Repair Motherboard Replacement: adım 4, 2 resimden 1. Asus Q551L Repair Motherboard Replacement: adım 4, 2 resimden 2.
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
  5. Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): adım 5, 3 resimden 1. Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): adım 5, 3 resimden 2. Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): adım 5, 3 resimden 3.
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
  6. Asus Q551L Repair Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Asus Q551L Repair Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Asus Q551L Repair Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove the fan by unscrewing the nine screws shown in the images.
    • The four colored wire and the black cable need to be pulled out gently.
    • There will be wires around the fan. Make sure they are not stuck to it.
    • You want to keep the fan if it still in good conditions.
  7. Asus Q551L Repair Motherboard Replacement: adım 7, 2 resimden 1. Asus Q551L Repair Motherboard Replacement: adım 7, 2 resimden 2.
    • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
  8. Asus Q551L Repair Motherboard Replacement: adım 8, 3 resimden 1. Asus Q551L Repair Motherboard Replacement: adım 8, 3 resimden 2. Asus Q551L Repair Motherboard Replacement: adım 8, 3 resimden 3.
    • Disconnect any cables that hold the motherboard.
    • Open up the white adjustable latch first to pull out the tapes.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
Robert Valentino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 2,515
