Ana içeriğe geç
Asus Q551L Screen Replacement
Neye ihtiyacın var
    1. Asus Q551L Screen Replacement, Back Panel: adım 1, 2 resimden 1. Asus Q551L Screen Replacement, Back Panel: adım 1, 2 resimden 2.
      • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q551L Screen Replacement: adım 2, 1 resimden 1.
      • Use the plastic opening tool to pry the back panel off the base of the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q551L Screen Replacement, Battery: adım 3, 2 resimden 1. Asus Q551L Screen Replacement, Battery: adım 3, 2 resimden 2.
      • Unscrew the four screws to remove the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q551L Screen Replacement: adım 4, 2 resimden 1. Asus Q551L Screen Replacement: adım 4, 2 resimden 2.
      • Un-clip both wire clips on the upper and right side of the battery.
      • Lift the battery out of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Q551L Screen Replacement, Screen: adım 5, 2 resimden 1. Asus Q551L Screen Replacement, Screen: adım 5, 2 resimden 2.
      • Use the metal spudger to gently lift the two plastic squares off the screen.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q551L Screen Replacement: adım 6, 2 resimden 1. Asus Q551L Screen Replacement: adım 6, 2 resimden 2.
      • Unscrew the two PH0 screws and set them aside.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q551L Screen Replacement: adım 7, 1 resimden 1.
      • Use the plastic opening tool to pry the front edges of the screen off of the back.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Q551L Screen Replacement: adım 8, 1 resimden 1.
      • Take off the tapes.
      • Gently pry the LCD from the front frame.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 37
Her zaman: 3,624
