Ana içeriğe geç
Asus Q552UB-BHI7T12 Screen Replacement
Neye ihtiyacın var
  1. Asus Q552UB-BHI7T12 Screen Replacement, Screen: adım 1, 2 resimden 1. Asus Q552UB-BHI7T12 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Remove the two screw covers by hand or by using the pointed end of a spudger.
  2. Asus Q552UB-BHI7T12 Screen Replacement: adım 2, 1 resimden 1.
    • Remove both screws with a Phillips head screwdriver.
  3. Asus Q552UB-BHI7T12 Screen Replacement: adım 3, 2 resimden 1. Asus Q552UB-BHI7T12 Screen Replacement: adım 3, 2 resimden 2.
    • Wedge an opening tool between the two halves of the screen.
    • Keep the two latches together and go completely around the screen to release all the latches.
  4. Asus Q552UB-BHI7T12 Screen Replacement: adım 4, 2 resimden 1. Asus Q552UB-BHI7T12 Screen Replacement: adım 4, 2 resimden 2.
    • Separate the two parts of the screen.
  5. Asus Q552UB-BHI7T12 Screen Replacement: adım 5, 1 resimden 1.
    • Remove any tape that is holding the screen in place.
  6. Asus Q552UB-BHI7T12 Screen Replacement: adım 6, 2 resimden 1. Asus Q552UB-BHI7T12 Screen Replacement: adım 6, 2 resimden 2.
    • Use an opening tool to lift out the screen after all the tape is removed.
    • The screen may be stuck due to any tape or any remaining glue.
  7. Asus Q552UB-BHI7T12 Screen Replacement: adım 7, 1 resimden 1.
    • Pull the screen horizontally away to remove the last cable attached to the screen.
Sonuç
Follow these instructions in reverse order to reassemble your device.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Can you show the connection on motherboard for LCD cable?
Bustelo Pilon - Yanıt
Does anyone know where I can get this same model replacement?
Anthony C - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 968
