Ana içeriğe geç
Asus R510CA-OB01 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus R510CA-OB01 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computer so that it is upside down. Position the computer with the front towards you.
  2. Asus R510CA-OB01 Hard Drive Replacement: adım 2, 2 resimden 1. Asus R510CA-OB01 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Loosen the two 12 mm screws on the bottom panel of your device using a Phillips size 0 bit.
  3. Asus R510CA-OB01 Hard Drive Replacement: adım 3, 3 resimden 1. Asus R510CA-OB01 Hard Drive Replacement: adım 3, 3 resimden 2. Asus R510CA-OB01 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  4. Asus R510CA-OB01 Hard Drive Replacement: adım 4, 3 resimden 1. Asus R510CA-OB01 Hard Drive Replacement: adım 4, 3 resimden 2. Asus R510CA-OB01 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Loosen the three 5 mm screws holding down the hard drive using a Phillips #00 bit.
  5. Asus R510CA-OB01 Hard Drive Replacement: adım 5, 2 resimden 1. Asus R510CA-OB01 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Slide the casing (hard drive bay) for the hard drive to the left.
    • Lift it to remove it from the device.
Sonuç
Blanche Pinto
437 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G4, Nance Fall 2017 USF Tampa, Team S3-G4, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G4
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 634
