Ana içeriğe geç
Asus R510CA-OB01 Optical Drive Replacement
Neye ihtiyacın var
  1. Asus R510CA-OB01 Optical Drive Replacement, Keyboard and Mousepad: adım 1, 1 resimden 1.
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computers that it is upside down. Position the computer with the front towards you.
  2. Asus R510CA-OB01 Optical Drive Replacement: adım 2, 1 resimden 1.
    • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
  3. Asus R510CA-OB01 Optical Drive Replacement: adım 3, 2 resimden 1. Asus R510CA-OB01 Optical Drive Replacement: adım 3, 2 resimden 2.
    • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
  4. Asus R510CA-OB01 Optical Drive Replacement: adım 4, 3 resimden 1. Asus R510CA-OB01 Optical Drive Replacement: adım 4, 3 resimden 2. Asus R510CA-OB01 Optical Drive Replacement: adım 4, 3 resimden 3.
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  5. Asus R510CA-OB01 Optical Drive Replacement: adım 5, 2 resimden 1. Asus R510CA-OB01 Optical Drive Replacement: adım 5, 2 resimden 2.
    • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
  6. Asus R510CA-OB01 Optical Drive Replacement: adım 6, 2 resimden 1. Asus R510CA-OB01 Optical Drive Replacement: adım 6, 2 resimden 2.
    • Turn the laptop the right way up and face it towards you.
    • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
    • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
  7. Asus R510CA-OB01 Optical Drive Replacement: adım 7, 2 resimden 1. Asus R510CA-OB01 Optical Drive Replacement: adım 7, 2 resimden 2.
    • Make sure that the entire cover has been released front the plastic pins.
    • Slowly lift the cover open from the front of the laptop but do not completely remove.
    • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
  8. Asus R510CA-OB01 Optical Drive Replacement: adım 8, 3 resimden 1. Asus R510CA-OB01 Optical Drive Replacement: adım 8, 3 resimden 2. Asus R510CA-OB01 Optical Drive Replacement: adım 8, 3 resimden 3.
    • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
    • The cable will slide out of its place.
  9. Asus R510CA-OB01 Optical Drive Replacement: adım 9, 2 resimden 1. Asus R510CA-OB01 Optical Drive Replacement: adım 9, 2 resimden 2.
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
  10. Asus R510CA-OB01 Optical Drive Replacement, Optical Drive: adım 10, 2 resimden 1. Asus R510CA-OB01 Optical Drive Replacement, Optical Drive: adım 10, 2 resimden 2.
    • Remove the 4.5mm silver screw in the top right corner using a Phillips #0 bit.
    • Remove the three 2mm silver screws using a Phillips #000 bit.
    • Remove the 5mm screw using a Phillips #1 bit that is holding the optical drive in place.
    • With your hands, gently slide the optical drive out of the laptop.
Sonuç
Mame
13 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Henning Spring 2019 IUPUI, Team S1-G2, Henning Spring 2019 üyesi
IUPUI-HENNING-S19S1G2
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 267
