Ana içeriğe geç
Asus R510LA-RS71 Screen Replacement
Neye ihtiyacın var
  1. Asus R510LA-RS71 Screen Replacement, Screen: adım 1, 3 resimden 1. Asus R510LA-RS71 Screen Replacement, Screen: adım 1, 3 resimden 2. Asus R510LA-RS71 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Using a metal spudger, pick out the stoppers located on the bottom left/right corners of the screen, revealing the screws underneath them.
    • Unscrew the two 4.25mm screws with the JIS 00 screwdriver.
  2. Asus R510LA-RS71 Screen Replacement: adım 2, 3 resimden 1. Asus R510LA-RS71 Screen Replacement: adım 2, 3 resimden 2. Asus R510LA-RS71 Screen Replacement: adım 2, 3 resimden 3.
    • Using the metal spudger, pry off the edges of the screen's frame from the outside.
  3. Asus R510LA-RS71 Screen Replacement: adım 3, 3 resimden 1. Asus R510LA-RS71 Screen Replacement: adım 3, 3 resimden 2. Asus R510LA-RS71 Screen Replacement: adım 3, 3 resimden 3.
    • There should be four silver brackets holding the screen in place underneath. Unscrew the center 3.35mm screws in each bracket as shown with the JIS 00 screwdriver.
  4. Asus R510LA-RS71 Screen Replacement: adım 4, 3 resimden 1. Asus R510LA-RS71 Screen Replacement: adım 4, 3 resimden 2. Asus R510LA-RS71 Screen Replacement: adım 4, 3 resimden 3.
    • Slowly remove the monitor from its recess.
  5. Asus R510LA-RS71 Screen Replacement: adım 5, 3 resimden 1. Asus R510LA-RS71 Screen Replacement: adım 5, 3 resimden 2. Asus R510LA-RS71 Screen Replacement: adım 5, 3 resimden 3.
    • Place the monitor face down. Slowly remove the adhesive tape on the back of the monitor, and remove the connector that the tape is holding.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Deliyanis Rosa
283 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Leahy Spring 2018 USF Tampa, Team S1-G6, Leahy Spring 2018 üyesi
USFT-LEAHY-S18S1G6
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 481
