Ana içeriğe geç
Asus R541UA-RB51 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus R541UA-RB51 Hard Drive Replacement, Keyboard: adım 1, 3 resimden 1. Asus R541UA-RB51 Hard Drive Replacement, Keyboard: adım 1, 3 resimden 2. Asus R541UA-RB51 Hard Drive Replacement, Keyboard: adım 1, 3 resimden 3.
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 Hard Drive Replacement: adım 2, 2 resimden 1. Asus R541UA-RB51 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 Hard Drive Replacement: adım 3, 2 resimden 1. Asus R541UA-RB51 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
  4. Asus R541UA-RB51 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Asus R541UA-RB51 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Locate the hard drive in the lower right hand corner in the computer. This device did not have a hard drive so a piece of cardboard was used as a substitute.
    • Remove the two 5.7 mm screws from the base. Use a Phillips #1 screwdriver to remove the screws. Lift up to remove the hard drive.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 670
