Giriş
If you want faster memory (SSD) or want to increase the storage of your current Asus R558UQ-DM513D, follow this guide to replace your laptop’s current Hard Disk Drive with a new SSD/HDD.
Make sure to save your current Hard Drive data on another device before you begin.
Make sure you turn off and unplug the laptop before starting the procedure.
Neye ihtiyacın var
Using the Phillips #0 screwdriver, remove the single 5 mm screw and remove the RAM access panel.
Remove the ten 5 mm screws using the same Phillips #0 screwdriver.
