Ana içeriğe geç
Asus R558UQ-DM513D SSD Replacement
Neye ihtiyacın var
  1. Asus R558UQ-DM513D SSD Replacement, HDD (Hard Disk Drive): adım 1, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the single 5 mm screw and remove the RAM access panel.
    • Remove the ten 5 mm screws using the same Phillips #0 screwdriver.
  2. Asus R558UQ-DM513D SSD Replacement: adım 2, 1 resimden 1.
    • Remove two 2 mm hidden screws using the Phillips #0 screwdriver.
  3. Asus R558UQ-DM513D SSD Replacement: adım 3, 1 resimden 1.
    • Remove the back cover of the laptop to expose the inner components.
  4. Asus R558UQ-DM513D SSD Replacement: adım 4, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the HDD in place.
  5. Asus R558UQ-DM513D SSD Replacement: adım 5, 1 resimden 1.
    • Gently take the left-side board containing the ports by simply sliding it in and taking it out while still connected to the wire.
  6. Asus R558UQ-DM513D SSD Replacement: adım 6, 1 resimden 1.
    • Slide the HDD out.
Sonuç
Deepanker Seth
133 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Where do I locate the hard drive on my Asus LF10MA -WB04 laptop?
Paulo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 47
Her zaman: 2,380
