Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Unlock the battery by pushing the switch to the right.
Push and hold the left switch, then pull the battery out.
Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
Disconnect the keyboard ribbon cables from the motherboard.
Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
Place your fingers along the left edge of the hard drive cover, and slide it to the right, then lift up.
Remove the Hard Drive and case from the laptop.
Remove the four Phillips #0 screws from the hard drive case.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Bottom cover holds only by 9 screws. You don’t need to remove 14 screws. All screws at the bottom with M2 5x7 label (do not remove two small screws. And one scre on the right in the middle without number on the metal plate). You don’t need to remove screw with M2 5x7 label on the right side, second from the corner.
