Ana içeriğe geç
Asus ROG G53SW-XT1 Optical Drive Replacement
Neye ihtiyacın var
  1. Asus ROG G53SW-XT1 Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug the power cable and flip the computer over.
  2. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 2, 1 resimden 1.
    • Unlock the battery by pushing the switch to the right.
  3. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 3, 2 resimden 1. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 3, 2 resimden 2.
    • Push and hold the left switch, then pull the battery out.
  4. Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: adım 4, 3 resimden 1. Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: adım 4, 3 resimden 2. Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: adım 4, 3 resimden 3.
    • Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
  5. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 5, 3 resimden 1. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 5, 3 resimden 2. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 5, 3 resimden 3.
    • Disconnect the keyboard ribbon cables from the motherboard.
  6. Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: adım 6, 3 resimden 1. Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: adım 6, 3 resimden 2. Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: adım 6, 3 resimden 3.
    • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
  7. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 7, 1 resimden 1.
    • Remove the fourteen Phillips #0 screws.
  8. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 8, 2 resimden 1. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 8, 2 resimden 2.
    • Flip the laptop over and pull off the bottom cover.
  9. Asus ROG G53SW-XT1 Optical Drive Replacement, Optical Drive: adım 9, 1 resimden 1.
    • Remove the single 7mm Phillips #0 screw holding the hard drive in place.
  10. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 10, 2 resimden 1. Asus ROG G53SW-XT1 Optical Drive Replacement: adım 10, 2 resimden 2.
    • Slide the hard drive out of the casing.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 244
