Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Parçalar
Hiçbir parça belirtilmedi.
  1. Unplug the power cable and flip the computer over.
    • Unplug the power cable and flip the computer over.
  2. Unlock the battery by pushing the switch to the right.
    • Unlock the battery by pushing the switch to the right.
  3. Push and hold the left switch, then pull the battery out. Push and hold the left switch, then pull the battery out.
    • Push and hold the left switch, then pull the battery out.
  4. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  5. Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free. Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free. Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
    • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
  6. Remove the fourteen Phillips #0 screws.
    • Remove the fourteen Phillips #0 screws.
  7. Flip the laptop over and pull off the bottom cover. Flip the laptop over and pull off the bottom cover.
    • Flip the laptop over and pull off the bottom cover.
  8. Push the metal tabs at the side of the RAM away from one another.
    • Push the metal tabs at the side of the RAM away from one another.
    • The RAM should pop up.
    • Pull the RAM out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
sia
124 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 193
