Ana içeriğe geç
Asus ROG G56JK CD Drive Replacement
Neye ihtiyacın var
  1. Asus ROG G56JK CD Drive Replacement, Battery: adım 1, 2 resimden 1. Asus ROG G56JK CD Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Push the slider to the opposite side, while pulling out the battery.
    • Remove the battery from the device.
  2. Asus ROG G56JK CD Drive Replacement, Hard Drive: adım 2, 1 resimden 1.
    • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
    • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
  3. Asus ROG G56JK CD Drive Replacement: adım 3, 1 resimden 1.
    • Slide the hard drive to left and remove it from the device.
  4. Asus ROG G56JK CD Drive Replacement, Back Panel: adım 4, 1 resimden 1.
    • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
  5. Asus ROG G56JK CD Drive Replacement: adım 5, 1 resimden 1.
    • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
    • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
  6. Asus ROG G56JK CD Drive Replacement, CD Drive: adım 6, 1 resimden 1.
    • Using a Phillips #0 screwdriver, unscrew the four 4mm screws.
  7. Asus ROG G56JK CD Drive Replacement: adım 7, 1 resimden 1.
    • Gently pull the CD drive out of the side of the laptop and remove it from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 694
