Giriş
If you need to install a new battery, access the battery with this guide. You may need to replace your battery if it doesn't charge or holds the same battery life as before. For this guide, you will need no tools. You will not need to do any difficult steps, but lifting up the latch with your finger to remove the battery .
Neye ihtiyacın var
With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
2 Yorum
The note bullet should just be a bullet. Check grammar on the Red bullet.
“With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.” The sentence is too wordy you can remove “Where you can see the battery pop slightly up”.
“With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.” Lots of wordiness.
Coreyai - Yanıt
