Ana içeriğe geç
Asus ROG G750JH-DB71 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
  2. Asus ROG G750JH-DB71 Hard Drive Replacement: adım 2, 3 resimden 1. Asus ROG G750JH-DB71 Hard Drive Replacement: adım 2, 3 resimden 2. Asus ROG G750JH-DB71 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
  3. Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Use a pick or your finger to lift up the plastic cover on back of the laptop.
    • Under the plastic cover is a screw, unscrew it using a Phillips #00 screwdriver.
    • The screw has a c lock so it can not be unscrewed completely. Once Its loose pry on the seam using a screwdriver or the iFixit pry tool.
  4. Asus ROG G750JH-DB71 Hard Drive Replacement: adım 4, 3 resimden 1. Asus ROG G750JH-DB71 Hard Drive Replacement: adım 4, 3 resimden 2. Asus ROG G750JH-DB71 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Remove the cover.
    • Remove the four 4.0 mm Phillips #00 screws holding in the hard drive caddy.
    • Push the caddy towards the open space in its compartment to remove it.
Sonuç
Devin Medeiros
219 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G5
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 128
