Giriş
This guide covers how to replace the hard drive in an Asus ROG G750JH-DB71.
The hard drive stores data on the device and makes sure it is kept even with the power disconnected. The hard drive stores the operating system which is necessary for the device to run. The hard drive may need to be replaced if the operating system is corrupted or the computer seems to be running slow.
This device accepts a 2.5-inch SSD.
Neye ihtiyacın var
Use a pick or your finger to lift up the plastic cover on back of the laptop.
Under the plastic cover is a screw, unscrew it using a Phillips #00 screwdriver.
