Ana içeriğe geç
Asus ROG G750JH-DB71 RAM Replacement
Neye ihtiyacın var
  1. Asus ROG G750JH-DB71 RAM Replacement, Battery: adım 1, 2 resimden 1. Asus ROG G750JH-DB71 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
  2. Asus ROG G750JH-DB71 RAM Replacement: adım 2, 3 resimden 1. Asus ROG G750JH-DB71 RAM Replacement: adım 2, 3 resimden 2. Asus ROG G750JH-DB71 RAM Replacement: adım 2, 3 resimden 3.
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
  3. Asus ROG G750JH-DB71 RAM Replacement, Asus ROG G750JH-DB71: adım 3, 3 resimden 1. Asus ROG G750JH-DB71 RAM Replacement, Asus ROG G750JH-DB71: adım 3, 3 resimden 2. Asus ROG G750JH-DB71 RAM Replacement, Asus ROG G750JH-DB71: adım 3, 3 resimden 3.
    • Use a spudger or your finger to lift up the plastic cover on the bottom of the laptop.
    • Under the plastic cover is a captive screw; unscrew it using a Phillips #00 screwdriver.
  4. Asus ROG G750JH-DB71 RAM Replacement: adım 4, 2 resimden 1. Asus ROG G750JH-DB71 RAM Replacement: adım 4, 2 resimden 2.
    • Remove the cover.
    • If your goal is to replace/remove only the hard drive, you don't have to complete the following disassembly steps and can go on to the hard drive replacement guide.
  5. Asus ROG G750JH-DB71 RAM Replacement: adım 5, 3 resimden 1. Asus ROG G750JH-DB71 RAM Replacement: adım 5, 3 resimden 2. Asus ROG G750JH-DB71 RAM Replacement: adım 5, 3 resimden 3.
    • Remove the hard drive by unscrewing the 4.4 mm Phillips #00 screws.
    • Remove all of the plastic caps around the edges using a pick or flathead screwdriver, and remove the screws underneath them. (one 13 mm Phillips #00, six 8 mm Phillips #00)
    • Remove the remaining screws underneath the cover . (six 8mm Phillips #00, three 1 mm Phillips #00)
  6. Asus ROG G750JH-DB71 RAM Replacement: adım 6, 3 resimden 1. Asus ROG G750JH-DB71 RAM Replacement: adım 6, 3 resimden 2. Asus ROG G750JH-DB71 RAM Replacement: adım 6, 3 resimden 3.
    • You will find a metal tab holding the CD Rom in place. Push on the tab with a flathead screwdriver or an iFixit tool to remove the CD Rom. It is located below a previously removed screw.
    • Do not pull the CD rom out from the side before pushing the metal tab as it will only damage the cover.
    • Remove the three (4 mm Phillips #00) screws that were previously covered by the CD rom.
  7. Asus ROG G750JH-DB71 RAM Replacement: adım 7, 3 resimden 1. Asus ROG G750JH-DB71 RAM Replacement: adım 7, 3 resimden 2. Asus ROG G750JH-DB71 RAM Replacement: adım 7, 3 resimden 3.
    • Once the screws are out and the CD rom is removed, the back cover can be taken off by hand.
    • Disconnect the speaker cables located in picture 1 and 2.
    • Remove two 8 mm Phillips #00 screws on each corner shown in picture 3.
  8. Asus ROG G750JH-DB71 RAM Replacement: adım 8, 3 resimden 1. Asus ROG G750JH-DB71 RAM Replacement: adım 8, 3 resimden 2. Asus ROG G750JH-DB71 RAM Replacement: adım 8, 3 resimden 3.
    • Pry the keyboard gently using the iFixit prying tool.
    • Make sure to unhook the cables and wires from the keyboard gently in Picture 3.
  9. Asus ROG G750JH-DB71 RAM Replacement: adım 9, 2 resimden 1. Asus ROG G750JH-DB71 RAM Replacement: adım 9, 2 resimden 2.
    • Now you can pull the keyboard off but make sure to do so carefully without damaging or scuffing any components.
    • Pull up and out at an angle to avoid damaging the internals of the laptop.
  10. Asus ROG G750JH-DB71 RAM Replacement, RAM: adım 10, 2 resimden 1. Asus ROG G750JH-DB71 RAM Replacement, RAM: adım 10, 2 resimden 2.
    • The RAM module is located directly in the center of the computer on top of the motherboard.
    • Push in the two levers on each side of the RAM module. This frees the module from the slot and allows removal.
    • Once loose, pull the RAM module away from the slot at a 45 degree angle as to not damage it.
Sonuç
James Mills
471 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G5
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 110
